JRay8
i have tried only a few times to work with purple heart. the reason i dont try very often is it always turns brown after i sand and finish it.
where does the deep purple color go and how do i get it back?
When my turning is complete; I heat the purpleheart with my propane torch while its spinning on the lathe. It brings out the color instantly for me. Pay close attention so you dont put burn marks on the wood.
I did a lot of research on purpleheart and found that UV Light and Oxygen both affected the color of the wood over time. The color will come back if put in the sun, a couple of days has been all it has taken in my experience. To keep the color you have to somehow block UV and oxygen. From my research I decided to go with penofin oil (99% uv inhibitor) and Deft Lacquer for the furniture I made from purple heart. 6 years later they are still a vibrant purple. Now they aren't sitting in front of a window mind you, I placed them where they do not get a lot of direct sunlight. For my pens, I still use a light coat of penofin oil and then put a CA finish on. So far the ones I've made from purpleheart have held up and look great after 3 years. The one thing I struggle with is the open grain. If I do any kind of engraving on the pen and want to color fill it, there is a good chance that the color fill will get into that open grain. My solution to that has been to get a good ca finish on, then do the engraving & color fill, then put it back on the lathe and build the CA finish up.
