Mapster
I have a debilitating problem at the moment. Everytime I turn a pen my mandrel unscrews from itself. I have the mandrel that screws onto the headstock and it is two pieces (as most are). It has the threaded part that screws onto the headstock and the rod. The rod keeps unscrewing from the part that screws onto the headstock
I thought it was just loose, tightened that rod as hard as I could and within a minute it was loose. Makes all kinds of screechy annoying noises. I then thought it was from cutting the blank, but it still came off within a minute while sanding. I made a pen and despite all of my desperate attempts it is horribly out of round.
I would greatly appreciate any ideas. I realize I will most likely need a new mandrel, but I don't see how that can be the problem. The way the lathe turns would tighten the rod, not loosen it, so I don't understand how it can turn the wrong way and unscrew while the lathe is tightening it at 3200 rpm. Turncrafter pro with mandrel saver. Thanks in advance
