silmar woes
JRay8
Arnold, MD
ok, i keep having trouble casting silmar. i can mix it the same every batch and get different results each time. mostly it does not set. i have had to put it in the oven to get it to harden. my wife didnt like that much. and when i have gotten it to set it was really brittle. almost powder like and had lots of voids. is there a secret dance or prayer that goes along with this stuff?​
I don't cast with silmar but you should invest in a toaster over and stop using the oven in the kitchen, I don't think fumes and food would taste very good, let alone the effects on your health.
I've been using Silmar 41 for years with no problems. At least no problems curing. It cures with heat but too much heat and it gets brittle. I use 3 drops of catalyst per ounce of resin. I stir until it turns a greenish blue tint, then add the color dyes if coloring. I let it set for 24 hours before even attempting to use it. I usually use a pressure tank and set it in a warm place. If your shop is cold, hang a clip on light above the cup of resin prior to adding the catalyst, to warm it up and thin it out a bit. It will mix much better and air will escape faster. The colder the room the slower the cure. Almost all of my casts come out tacky. That's just a property of poly resin. I let it set in the sun for an hour or just let warm air get to it for a little while, and the problem is fixed. I would not recommend using the kitchen oven but that's just me. If they get brittle they'll shatter real easy. Some color agents will soften the resin like oil based paints. When that happens I add a couple extra drops of catalyst to the cup of resin. ( not the ounce ). Hope this helps. Good luck, John
+1 on a toaster oven. I will also preheat the molds, and after the pour I will put them back in the oven for 90 min. I will also heat the resin.
If you're using enough catalyst but it's only setting in chunks, you're not mixing it well.
Remember, PR has lots of working time. Spend 5 minutes mixing, making sure you scrape the sides and bottom of your cup/bowl/whatever while mixing.
You do realize that the amount and type of coloring agent you use can greatly inhibit the chemical reaction, thus slowing the "setting" of the blanks, don't you?
We had a burgundy that took two days to start setting. We had a black that set so fast it was a challenge to pour it.
Do you charge more for those that take longer to cure:biggrin::biggrin:?Time is money, you know!
Do a good turn daily!
Don
Didn't think of that Don!!!
We discontinued it after the second time I spilled the goo while fetching my morning coffee!!! It was clear I was not "trainable" for this one.:biggrin::biggrin:
