clapiana
Any good jigs to drill a dowel vertical on a drill press? The dowel is usually 1" round by 6" tall and I am using a 1/2" bit. Holding it by hand didn't work well with the torque produced off the 1/2 bit.
I am using a hack....a piece of 2x4 with a 45deg notch cut into it nailed to a base that I clamp down and I use a clamp to hold the dowel to the 2x4 but I am hoping for something better.
What do you use which works well?
