Pool Cue Help
See more from Turned Around
Turned Around
Houston, TX
I really want to make a pool cue, but I don't know where to get the parts to have it broken down to 2-4 pieces. I know that a 2 piece cue is typical, but I'd kind of like to make a 4 piece to have a smaller carrying case. Either way, I don't know where to get the hardware for one.
Anybody?
Also, suggestions anf tips on making one would help out, too.
Thanks,
Nic
moke
Cedar Rapids, Iowa
Nic--
I am going to make a multi- sectioned cane for an in-law, actually a tipling stick, and I have found some parts for sectioning and a glass tube in Craft supplies USA. THis may require some modification on your part, but I think it might be worth a look.
Turned Around
Houston, TX
Nic--
i thought about that, but for the first one, i kind of wanted to do a 'ready to go' type kit.
glycerine
Fayetteville, NC
I would PM IAP member "Willee". He used to make custom cues and now does more pen stuff as far as I know. Surely he can point you in the right direction...
EDIT: I just looked at Willee's profile and it looks like he hasn't been around for a while. Maybe you can find some contact info at www.willeecue.com
EBorraga
Passed Away July 17, 2022
Louisville, KY
Willee sold all of his equipment, and doesn't get on the internet very much. He's one of the better cue makers out there.
As for cue making, no one makes 4 piece cues. All are 2 piece. It takes most cuemakers atleast a year to make a cue from start to finish. Reason for that is to eliminate warpage. Even dry wood has to aclimate itself everytime you make a cut on it. I was making pool cues before I started with pens. On average I do about 15 cues a year. I can give you tons of info if you would like. But you need some different machinery to do cues. My cuemaking lathe costs a little over $2500.00 new.
Here are a few sites to peak your interest.
Cuesmith.com
Cuecomponents.com
Cuestik.com
Prathercue.com
8ball48043
Boynton Beach, Florida
Nic, There are a number of companies in the U.S. that provide ALL of the stuff that you'll need.
Start with Atlas Billiard Supply: http://www.cuestik.com/
And, Schmelke Pool CUes: http://www.schmelkecue.com/index.php?cPath=5
I have worked with both firms and they are both good sources.
Good luck.
Anybody?
Thanks,
Nic
