Drilling a Square Hole
There is an antique tool that does this. Don't remember the details but it was on the New Yankee Workshop once. It was a hand tool.
square hole drill
back in my machinist days we used to use something called a watts drill to make square holes. we even had hex hole drills also. you had a square guide you fastened to the end of the material. the drill, for the square had three cutting edges. operated similar to a wenkle engine. i believe the hex drill had 5 sides but not sure. that was a long time ago, about 20 years. if you go to this web site you can look at one of them and watch a video.
http://www.ohgizmo.com/2009/10/07/square-holes-drilled-with-a-watts-drill-blows-my-mind/
check it out. if i remember correctly it worked pretty well.
Might have been on New Yankee but I remember seeing Roy Underhill on the Woodwrights Shop use one. Odd looking tool, set up like a breast drill. The bit danced around following a square template IIRC.
Jeff in northern Wisconsin
I would think something like this would have a huge tear out problem in wood. The other thing I see is that you still have an arc in the corners. I think for the time being I will stick to a mortising machine, although the concept is interesting.
Did the same thing years ago. Bit was in a floating holder.
http://www.youtube.com/watch?v=iY-aCu6erP0
This is the one I was trying to get uploaded.
Guy in the shop showed me this one yesterday.
