Homemade disk sander
Alejanders
Moscow, Russia
I want to tell a story of my disk sander.
First colclusion from all it - if you WANT something - you may DO it.
Second - if you can buy good stuff - buy it, not make.
Greedy person pays twice.
My first woodworks was handle for a knife (junksteel Indian damascus) and wooden USB thumbdrive.
I have made it with file, sanpaper and small metal saw (that was bought to open coconut).
That is a knife:
s640x480
And thumbdrive:
s640x480
It was not easy, so I decided to use some machine tool. I have no workshop (except balcony 3*6 feet) so looked
for compact or disassemblable stuff.
First "sander" was screw gun with clamp and 125mm (5") sanding disk with box as table.
I have no photo with disk, but there is photo with felt disk.
There was a lot of disadvantages (noise, low accuracy and control etc...) so I decided to make "real disk sander".
Draft:
attachment.php
Writing means: Side view, motor, angle grinder velcro disk, table.
I took 90W 3-phase asyncronic motor (2750 rpm), made control unit for it. You may see main power switch with LED (left), reverse switch (right),
ON/OFF switch (green on top) and start (blue on top).
I used 12 mm (1/2") plywood as bed.
Quick-removable table holds with 4 pins. It allows to change velcro sanpaper very quck.
Also I found turner, who made for me metal sleeves to fit sanding disk on motor's shaft.
Motor is quiet and low powered (about 50W on 1-phase), that is enough for small things like knife handle or thumbdrive.
Main disadvantage was softness and flexibility of sandind disk. Also table had no angle guide (it is senseless for flexible disk).
But soft disk had advantage - it was very comfortable to make curves and I made a lot of things on that sender.
Also I can attach Jacob chuck and use buffing wheels.
Stuff made on that sander:
0001bq5a
s640x480
s640x480
s640x480
s640x480
s640x480
0004fpe3
s640x480
I have looked for firm disk, but disks for angle sander was flex or curve. So I decided to make new table and firm disk.
Bellow is a design: table with rotating mechanism, angle guide and disk. I gaved that drawings to turner and he made for me disk, angle guide and table.
I used 15 mm (5/8") plywood and 5 mm (1/5") textolite (micatra) as sander bed.
Same contril unit, plywood disk with velcro.
Now sander much bigger and I cannot store it on windowstill. :)
But now it can be called sander.
Drawings:
attachment.php
attachment.php
attachment.php
Wow,you do great work! I like how the table swings away to easily change the paper,very nice design.
Your woodworking projects look really cool,my favorite is the wooden mouse.
Very creative!
Steve
And here I sit complaining because I work out of half of a two car garage with real tools. It reminds me of a sign I once saw in a shoe shop, "I complained about having no shoes until I saw a man with no feet."
Alexander your work is outstanding, both your woodwork and the tools you have designed and built to work your wood. Your segmenting is mind blowing. I can only wonder what you could do in a full shop. Keep up the good work and congratulations.
Charles
Very nice! Are your thumbdrives from kits, or are you just buying them and taking them apart and making a new housing?
I buy thumbdrive and disasseble it. bensoelberg gaved link to my topic about it.
Do you need detailded how-to guide?
Really cool. Need is the mother of invention. Great segmenting by the way.
I have wrote about it already. There is a link http://www.penturners.org/forum/showthread.php?t=79868 .
Charles
Ha... Two car garage... You have a lot of place.
There is my "workshop". Sorry for mess. :)
attachment.php
attachment.php
attachment.php
