thewishman
Beautiful! Short and sweet.
That's funny. I was wandering what on earth you were talking about so I watched the video again. I watched it once after recording it then once again after uploading it and neither time did I catch the music playing, I guess I'm just so used to it. No problem though, there is no extra charge for the entertainment! Good thing it's over 50 years old, else someone would be calling me wanting their royalties! :biggrin:Thanks George great video...love the 'sound track' too
JeffG
George,
Do you do anything differently for Polyester Resin? I am having a devil of a time cutting threads in PR! It shouldn't be as hard as it is.....Especially after watching your video.
It is almost like my dies are stripping the PR from the tenon. Might also be that the taps and dies I have are not very good either! They are from HF! I should just break down and get some of the most common threads from a better set!
Thanks! Nice video by the way!!
Fred
Is using the tap pretty much the same? I'm guessing that I need to get a tap handle to turn it properly. Would it work to hold the tap in a drill chuck?
George,
Fred
After all that, I found that for tapping the soft material we use in pens all you need to do is mount the blank in the collet chuck as shown in the video then put the tap into a Jacobs drill chuck which is mounted in the tailstock.
My tailstock glides on the bed so smoothly that I just advance the tailstock by hand whild grasping and turning the collet chuck as the tap is fed into the blank. Again... don't force it but it really helps to have a tailstock that isn't half rusted to the bed and is real jerky and hard to move.
George,
Fred
Fred, I have one of those chap OneHungLo tap and die sets, all they are really good for is cleaning up existing threads. In my experience they are not suitable for cutting nice clean threads in anything. Even though PR is not as hard as steel etc, a good quality sharp HSS tap or die makes a world of difference.
Most of my single tap/die sets cost appreciably more that a whole cheap boxed OneHungLo set of taps and dies.
About the video, Does THE Ursus Americanus deficate in the forrest?
Skiprat posted the coolest little tool ever, back some time ago.
It is a little spring loaded device that keeps constant and uniform pressure on the tap. I ended up making my own little deal, because I couldn't find one like skip's
And YES ERIC they do defecate in coniferous environments, as well as dicidiuos ones! I've seen 'em do it! My question is do they ALWAYS wipe with bunny rabbits?![]()
Thank you, Lenny. My home built, center punch conversion only works marginally well. That is EXACTLY what I was looking for and never found it at LMS!
AND A BIG THANK YOU, George for the video. I always pick up something great with your tutitorials! Cutting the chamfer will make this MUCH easier for me. I think that was the missing ingredient!
Andy, I was thinking about how I could do a similar thing ....(hadn't figured it out yet though)
I'm almost positive most bears are left handed, here's proof, sorta.....!
I snapped this photo out behind my house recently! :biggrin:
Good to see your figuring out your new camera George! :biggrin::biggrin::biggrin:
