ToddMR
So at work the other day I was sitting there and came up with an idea of using sticky colored stars on a black tube to make a cool looking pen. Was the first time I cast using a pressure pot too. The result is below. I need some ideas to avoid the problems I ran into. The first issue is the black enamel came off on the ends and different parts I am sure due to the heat of the resin curing. Also some of the stars coloring faded off too. Overall I think it is a good idea and looks good. There was a crack in the blank but that was caused by me cleaning out the middle of the tube where some resin got in. This time I am going to use a nickle tube which will correct the color of the tube coming off I think. I am wondering if I ought to do a CA finish over the stars first to prevent the discoloration on the stars. Any help I would be thankful for.
