My New Camo
See more from cnirenberg
cnirenberg
Fort Myers, Fl
Well, its finally finished. Used the multi start set for the cap and nib and postable end. Metric for everything else. I had some extra time at lunch one day and sketched up a set of cartoons for it too. Hope you all like it. All and any comments welcomed.
Pretty nice kit less. the square sends seem to make it look heavy, I wonder if the cap were a bit tapered into the center band area if it would have the same durability.
Ken,
It's really not that heavy. Shorter than I'm used to but not by much, and it is fairly comfortable to hold. I messed up the schmidt style nib and went with the blunted look. I wanted to try something different than just having a step where the nib meets the barrel, hence the smallish arc. With that accomplished, I felt it necessary to cover that transition with the cap, thereby making her a bit fatter in the hips.....
Cris, It's about time:biggrin: Glad to see you finally found time to finish it. As for your "cartoons", I need to get you to do a set for my next pen. Knocked those out at lunch, did you?
Mike,
Thanks. Basketball is almost over, and if we don't schedule something else for Saturdays, I should have 1 or 2 free......Let me know.
