Monty
Group Buy Coordinator
Drilling a 7/64" hole in a piece of antler. Give you one guess what happened. The bit broke off about 1/4" in the hole. Any suggestions for getting the broken piece out would be greatly appreciated.
Not feasible for the blankDrill smaller hole from the other side and push bit out entry hole.
Nothing to grab hold of. The bit is about 1/4" inside the blankIf that isnt possible perhaps hemostats in the drill lands and twist backwards?
I've never seen one for 7/64"could an ez-out tool work like on a broken bolt?
Don't have an 1/8" ID tube, besides, that would make the hole too big.Any chance to slide a tube over it and see if it will work lose?
Can't really go much bigger, maybe 1/8", but that would be thge max size for the holeIs 7/64" the finish size for the hole? If not what size are you going to? If you are going bigger you may be able to use a trick to get out broken pieces of center drills that machinist use. I will try to explain after you answer if you are going bigger or not.
jimskio
Just trying to salvage this piece of antler. It matches perfect with the other two pieces for the project.Throw it away. This is Texas. Deer are everywhere.
I meant to give you some wood before you left and forgot. Sorry.
I will send you some antler if you want
Enjoying your lathe? I hope so. I miss it. Give it a pet for me.
