Do you know where to find
phillywood
San Antonio, TX, 78250, USA
Does any one know where I can find a used part for this tool, Please?
A welder friend has given me this tool which is a Delta
6" Belt and 12" Disc, Abrasive Finishing Machine,
(Model 31-731) the pic.is attached.​
I am missing the table that goes in fornt of the disk and also the guard that goes at the end of the belt, I am looking for used parts the new ones are pretty expensive.
thanks for looking and your help.
parts i am looking for are 100-114- and 162​
  • AFM7E-1.pdf
    AFM7E-1.pdf
  • AFM7E-2.pdf
    AFM7E-2.pdf
210-732-1221
That's the number for the Delta Service Center closest to you. Good Luck!
Scott.
Scott, thank you for this number, I am aware of where they are and they are right down one exit form the woodcraft store. I was trying to find used one so it won't cost as much as the newer ones. I am very well aware of the new one's cost. Thank you for the info..
I don't know about used parts, but you might see if there is a local machinist who could make one. I broke the tool rest on my lathe and had one made for $25. Now it is made of steel rather than cast iron and it works better then the original. It is a little ugly though.
You might be able to buy a new one, use it as a pattern to make a home-made version and then return it and save the money.
