Splinter
I purchased a lightly used Jet JML-1014 mini lathe yesterday. It had been stored in a metal storage building for some time. It had some light rust on the bed but no pitting, etc. The seller plugged it in and it ran as smooth as a top.
Today I cleaned it up and it was looking great. Rust came off - no problem. I checked it on a couple speeds and it ran really smooth. I put a small buffing bonnet on it to buff a bowl out and within 5 minutes I hear what sounded like a crackle noise one time and then it began to make a slight growling noise and it began to bog down and run about a 1/3 of the set speed. I removed the motor, took the fan off the motor shaft and plugged it back in and it still ran slow and soon the motor was rather warm to the touch. I removed the armature and the bearing on each end of the armature shaft turned but probably not as free as I thought they should. I sprayed them good with silicon spray and put the armature back in but it still was running slow.
Any ideas as to the problem? Is it the bearings or has the motor gone bad?
How do you remove the bearings from the shaft?
