truckerdave
I am not sure but I think I have a problem when drilling on my lathe.
My drill bit only travels 2" when I extend the ?QUILL? all the way out. My holes are not deep enough to accomodate the tubes for some of the pens I want to turn. I appreciate the accurracy and better control that drilling on my lathe gives me but if I can't drill deep enough, it does me no good.
The problem, I think, is the drill bit ?ADAPTOR? is too long and I lose about 5/8" in travel because I have to extend the QUILL out more to accomodate the drill bit chuck than if I am using the live center.
I will try to attach some photos that may better explain what I am seeing as I may not be clear.
From left to right:
pic 1 shows the MINIMUM extenension needed for the live center to be fully seated in the tail stock.
pic 2 shows the MINIMUM extension needed for the drill chuck to be fully seated in the tailstock.
pic 3 shows two lines where I marked the difference between the two pieces. I lose about 5/8" of travel.
pic 4 shows the two ?INSERTS? side by side. There seems to be no reason as why I am losing the 5/8".
By looking at the pics and my description, what is wrong here???
I am very frustrated!!!
I thought drilling on the lathe would eliminate all the problems associated with owning a junky, cheap drill press but now I am thinking I wasted my money on the ?ADAPTOR? and the drill chuck.
I am wondering if I should have just spent the money on a better, bigger drill press.
From left to right:
