The drill is a 5/32 and I got mine from Grainger, it was an extra long aircraft bit good luck H
Thanks H, Any idea what size the recess needs to be for the nib to fit?
A 5/32 is all you need, it allows some air space between the cartridge and the pen. it may only be a 1/32 but that is all you need to prevent binding.
Bic pens require a very small pin hole drilled somewhere in the body of the pen. I use a pin vise with a 1/64th bit. Somehow they will lock up and start leaking.
