navycop
My wife says that if I am not using the computer I should turn it off. I told her that it is OK to leave it on all day and turn off at bedtime. She turns it off then I have to wait till it comes on to do anything.
It is 2 maybe 3 yrs old.How old is the computer. CRT Monitors suck electricity. Just turn it off. You can leave the CPU on.
The school I teach at needed to cut huge amounts off the electricity bill. When we all started turning off our CRT monitors they saved a crap load, at least that is what they said.
I never shut mine down unless there is a power outage. Flat Screen goes to a screensaver after 15 minutes of no keystrokes and goes black after an hour. Comes back up with a key stroke or movement of the mouse. I just stop all the programs and let the CPU run. My antivirus does a run every night and a full run once a week at 2am. I clear temporary files and defrag every couple of days. Now and then after doing that I will shut all the way down for 30 minutes and let it reboot but not very often.
I think LOML is talking about power draw.Are we talking power draw, or safety for the computer?
A computer will draw a lot more power when on then off - but it also has 'phantom' draw when off and still plugged in...about 40 watts in sleep mode, and 15 watts when completely turned off (compared to about 200 watts in 'on' mode)
But in terms of running properly, I don't think it really matters, I always put mine in standby during the day, and off at night....
I enabled the hibernate on my computer. Is there a way for the standby to turn to hibernate by itself. I was thinking a friends computer had "hibernate, turn off, restart". He didn't have to hold the shift key.There is a very easy way to compromise. Don't shut down....hibernate. If you hold down the shift key when you are at the shutdown screen, the "standby" turns into "hibernate". When the computer hibernates, it shuts down completely. But before it does, it saves everything it is doing.
When you start it back up again it restarts in about 30 or 40 seconds and you are right back where you were when it hibernated.
All these settings can be adjusted on the "power options" in the control panel.
(I've had my own computer consulting business for 30 years)
YOU WIN! Go dance around. A computer (other than a monitor, which "sleeps" when not in use, uses virtually NO power.
ADDITIONALY, 86.347 percent of ALL fatal computer failures occur on "boot up" -DAMHIKT! Mine are so old, I'd NEVER turn 'em off!
It used to be a heavy power user to leave the computer and moniter on. Now adays, they go into sleep mode. They basicly shutdown every thing except what is necessary to just sit there.
So you win.
Now ask your wife if she unplugs the tv, the stereo, the cell phone charger and many other electronics, it's a small amount but their still using electricity when turned off.
Curt
Again, the only problem with leaving the computer in the standby mode, is if you have a power failure it can corrupt files or lose data. Here in AZ where we have daily thunderstorm/lightning storms every afternoon during monsoon, standby is NOT a good idea.
Without getting really technical here, there is a setting in the CMOS of every computer made since 1999 called "wake on..." which allows even servers TI "sleep" when there is no demand. Yet, when a LAN card, etc pings the machine, it wakes up. A very nice little trick for print servers, file servers, home automation, alarm systems, et. al.
And Sharon is exactly correct. LED and LCD both consume more power than cathode ray monitors. The "trade off" that makes then green is they produce far less heat outside the unit.
Mike, while you have gotten lots of good information from some very knowledgeable people, there is one thing I can add with some certainty, based on the fact that today is my 33rd wedding anniversary ..... regardless of facts, your wife is RIGHT! :biggrin:![]()
