Hi Darrell , the problem you are having is twofold . First you are most likely trying to use the tool at the wrong angle and second , you are being way too aggressive with it .
I use my Hunter tool to round over ALL my blanks from wood to metals . The Hunter tool is very aggressive if held wrong , you should be holding it an aprox 45 degree angle to the work . This will give a shearing cut with the tool and control the aggressiveness of the cup shaped cutter . When held at a 90 degree angle to the work it will dig in and tear out chunks of the blank . The Hunter tool is a wonderful tool for quickly rounding down or shaping the blanks , but it has a learning curve that takes awhile to get proficient with .
Try holding the tool with the cutter edge almost straight up and down then slowly rotate it until it starts to cut . Take slow passes with the tool letting the cutting edge do the work , these cutters are very sharp and will cut with very little pressure . Once you get used to how it cuts you can adjust the angle you hold it at to be more or less aggressive , when you hit the "Sweet Spot" you will get longer streamers that fly off the cutter .
Good luck and if you need any further help , feel free to post here or PM me for further help .
