Attention, all "metal heads"
PenMan1
Eatonton, Georgia
I need a small metal press. What I want is a press similar to an old "wringer type" washing machine ringer. It doesn't have to be able to handle much. Its sole purpose will be to flatten bottle caps.
It does however need to be cheap! Any suggestions as to where I might find such a critter will be greatly appreciated.
You could make one yourself.
Get a couple rollers from the store where you buy gate making supplies....these are the verticle rollers that keeps the gate straight as you roll it back and forth on the tracks.
From there you can fab it up any way that suits your application.
Barney
Andy what you are looking for is a rolling Mill, there is an outfit called 46 Jewelry supply that has or used to have a great deal on an imported mill, they were only about 150.00. Check feeBay
Andy -- jewlers rollers will do it but are costly You need steel rollers or forms and the rubber on an old wringer is out
These are also called slip rollers
Harbor freight may be your friend -- the internet search is hard to find things that I have seen in the store
I have a strap (steel) roller I got at HF for about $60 that bends steel strap into a circle with three rollers and a hand crank. putting the bottle cap in on a piece of strap and cranking it through -
Planishing metal is an old art -- takes a form and a hammer - HF sells small planishing forms that I have see sometimes --
Worst case -- two pieces of smooth pipe and a hammer to form shape it
I presume you are seeking a curve as in around the tube on a pen.....
How about a "heavy duty" pasta machine? :biggrin:
This might actually work!!!! I have a way to bend the bottle caps, I just need a way to flatten them while keeping the "crimps" along the bottom edge in tact. In my particular case, it's all about preserving the "crimp".
I'm pretty sure that KenV nailed exactly what I need. Now, if I can can just find a slip roller press for around $50.
They look like the treats the dog leaves me, when I hit them with the pipe and hammer.
I have one of these if you want to experiment send me a pm.
attachment.php
Andy, what about an arbor press from harbor freight? Last I looked they're around $30 and then just come up with a metal plate setup to evenly distribute pressure.
Mike is right about the price of this one. There are some for about 1/2 that that aren't as well built, but like I said, would be happy to do some for you.
Thanks, Justin.
I may do something like that. Bruce has generously offered to flatten some caps for me. Right now, I CAN afford to pay him. I can't really justify even $100 for this little project, EVEN though I do love cool tools such as this one!
All you need is a sledge hammer. Or...how about production stamping..you walk down to the train tracks, lay out all you bottle caps on the tracks and wait for the train to come rolling by! Won't cost you but gas money to get there.
Don't forget to put some bubble gum under each cap.......or you'll never see them again!!! :smile:
