Best tube color
rebfan04
Flowood, MS
Doing a Sierra, so not much material left on blank. I've got an acrylic with yellow and blue swirl that you can see light thru after drilling. What's the best color to paint tube? Would it be yellow, which isn't a perfect match or white, or would it be best to reverse paint blank a color?
Reverse paint your blanks. Why? Doing so prevents you from seing the bubbles and swirls of the glue through the blanks.
Ditto on what Shane said. Yellow could turn your blue parts greenish.
Paint a band of yellow on a dowel, next to it one in white. Insert the painted dowel into the hole and see which effect you think you will like better.
reverse paint????
OK - so I'm dumb - well not dumb, ignorant perhaps is a better word. What is reverse paint. Does that mean paint the inside of the blank?
I like your idea so much I think I'll be painting several dowels in the next few days. Great One!:smile:
Affirm, Painting the inside of the drilled out blank prevents the glue or tube from showing through when finished.
Genius! Why is it the most obvious ideas escape most of us... :confused:
Between your idea here and the ones Ed gave me on the phone last night, I can't wait to get in the shop this weekend and try them out!! :biggrin:
If you really want a near perfect match, reverse paint in yellow AND blue. Start with the color that is most transparent. Using a matchnig color, carefully paint the walls of the drilled hole approximately in the area where that color occurs. Let it dry overnight. Then paint the entire inside of the hole the the other color.
I use a Q-tip for painting, pull off up to half of the cotton to get finer details in painting. The same approach works well to put color in any nearly transparent blank. On a whitish nearly transparent blank try putting on a random swirl of a color like blue. Then come back the next day and paint the entire inside with green. It makes for great depth of color.
I was going to put this up for "Tip of the Week".
Now I think it's a tie. But I will be doing both of these in the future.
EDIT: I should say a Tip of the Week for me. I'm sure many of the people who have been around for awhile already know these. But for relative newbies (Like me), these are very helpful.
