islandturner
After 35 years of using a table saw, I nearly got my 'bell rung' in the shop yesterday – my first table saw 'mishap'.
I needed a strip of light colored veneer, so was ripping a 1/8" strip off a piece of rough 2 X 8 yellow cedar about 12" long. The 2 X 8 was between the blade and the fence – the strip came loose on the outside of the blade at the completion of the cut. I was worried about the strip kicking back by pinching between the blade and the blade guard, and was extremely careful to prevent that.
So the cut over, I was standing examining the strip, holding it just a few inches below my chin, when the 2 X 8 vibrated back until the bottom left hand corner slowly engaged the blade – I'd foolishly left the saw running (had another piece to run through). The 2 X 8 caught and was flung like a frisbee, hitting me in the back of my hand, driving it so hard into my upper chest, that there is a slight bruise there this morning. Then it deflected into the wall behind my work bench, smashing a small plastic parts bin. My hand took the force of the blow. With a gash on my big knuckle, now swollen almost instantly to double its size, I thought for sure it was broken. As the numbness subsided, I could tell it's okay, and I have full use of it. I was incredibly lucky – if 6" or so higher, it would have hit me in the throat or face.
A big powerful Delta, this saw doesn't have a kickback guard or blade cover – bought it second hand that way 10 years ago.
Lessons learned; never leave work unattended on the table saw top with the motor running. Always turn off the motor when the saw is not actually being used. Never stand behind the saw in the kickback zone. If possible, don't use a table saw without an anti-kickback device of some kind. I think it's time for a new one with a guard… :frown:
Scared the begeezus out of me….
