Full size Gentlemans pen in Buckeye
See more from terryf
terryf
Pretoria, South Africa
I got this buckeye from Isaac - very soft and easy to work with - not that easy to finish! Interestingly enough, this is the first time I have found my out of round to not be my fault - the end cap was warped - quick blow with the four pounder and it was close as dammit.
Thanks for looking :smile:
Chris, if you cant fix something with a hammer you have an electrical problem and in times of crisis, even they can be fixed with a hammer; permanently!!!
Thanks for the comments :)
The hammer skillfully and correctly applied is an indispensable tool for nearly all maintenance electricians. Please, for this answer, I must remain anonymous.
Charles OOPS!
Beautiful wood and you made a gorgeous pen from it ! I'll have remember to add a hammer to my arsenal of turning tools :biggrin:. Regards, Doc
When the electrician was wiring my shop and burying the ground wire, I offered the use of my hammer. He said an electrician only needs 2 tools - a pliers and a screw driver. Used the pliers as a hammer to bang on the screw driver to push the wire in the ground.
Nice pen.
