65GTMustang
I am considering the purchase of new bushings to turn by center.
I was hoping to get some advice before I spend a bunch of money before doing so.
I have a few sets that came with a trade and I really like turning with them
I get a much better pen than if I use a mandrel.
I have 4 or 5 mandrels and I have checked to make sure my lathe is running true - for whatever reason I am getting a high / low spot on both ends of my pens (definitely not turning true)???
I have tried brand new mandrel shafts, adjusting the tightness of the brass nut, using the mandrel saver...etc... Even the best result I am getting is not very good and some adjustments are needed.
When I use a set of CTB I don't have a problem?
What would you do?
Kevin
What would you do?
Kevin
