Katsin
I'm getting very small micro-pitting in my CA finish and it is driving me crazy. Has anyone else encountered this?
I've been sanding the blank up to 12k MM, then I clean with denatured alcohol, then about 8 coats of medium CA with accelerator in between each coat. Then I MM up to 12k again and finish with plastic polish.
I was able to reduce pitting by re-sanding the CA a second time but I think I could blow through the CA if I keep at it and end off worse.
Any techniques to try to reduce pitting?
