Back in December I bought 14 Artisan Sienna 10K pen kits for an upcoming project for a non-profit organization. I'm to the point of assembling the first test pen and I find that the pen tip where it meets the should of the body is a sloppy loose fit. The cap end presses in just fine. But the bottom fit is so loose even if the friction of the mechanism at the top holds the pen together you'll be able to feel the looseness at the point end. This can't be normal. Has anyone else run into this problem.? I'll be calling CSUSA first thing Monday but I'm wondering if this was a bad batch and if anyone else has run across this.
