76winger
I went out and tried some more combinations to try and get the color balance, brightness and sharpness levels I would expect to get out of my DSLR without having to run through a lot of post-shooting edits in an image editor.
I first removed the Florissant lights on the top which weren't daylights bulbs like I thought they were and put in a pair of tubes that were 6500K daylight bulbs, which match the 6500k CFL lamps in the bases on the sides and front. The photo booth was made from PVC and covered with a white sheet.
I maintained Aperture Priority automatic settings to keep the depth of field in control and used f20 for my setting. Then I used the camera's exposure compensation feature and varied the exposures from 0 through +2 to start getting a feel for what I needed to get the exposure I felt to be the best. For my particular lighting setup and ISO setting of 400, this resulted in shutter speeds varying from 1/125th to 1/25th.
The first row was with the custom white balance settings I've played with for other photos I've taken this past week. They were fair but left a greenish tint I wasn't happy with.
I then tried a Florissant filter, but all of the results for them were to reddish (magenta?) to suit.
So I removed the filter and started playing with the white balance settings, first Florissant, then daylight (which I think resulted in the bluish colored ones). So decided the Florissant white balance, adjusted to -3 provided the closest to acceptable I could get, but I skipped some of the exposure compensation settings and believed I missed the one that would have worked best. So Stepped through them again and came up with one that I felt was about as close as I could get it, without it looking over exposes. That being DSC_0029.JPG in the thumbnail display.
But that was still a little too soft for me, I wanted a little contrast in the photo, so moved the front light into the booth, so it would shine directly on the pen instead of being diffused through the sheet. I think this helped highlight the 3D features of the pen and show off it's details a bit more, and provided a slight shadow on the back side. After bracketing a set with the light on the inside, I ended up selecting DSC_0036.JPG as my favorite for this exercise.
I've attach my two "finalists" for everyone to review. They're straight out of the camera and unedited at this point.
What do you all think?
