Apologies for that title!!!:wink: But that's YOUR mind at work.:tongue:
I went down to the shop today to get some CA......and while I was there, they had a deal on some Butane brazing torches, so I got one and some flux etc.
(I had to go back later for the CA that I forgot:redface
You know what it's like.:wink:
Now I had to find a use for the brazing gadget, so I made a quick pen similar to one I made a few years ago but this time I brazed the rods in the holes. Worked well, but took a bit of cleaning up afterwards.
I used two 6mm s/s dome nuts, one regular 6mm s/s nut, the thread from a 6mm s/s bolt and cut 6 lengths of s/s mig welding wire.
I later changed 2 lengths to one much longer one...(clip)
(6mm is about 1/4 inch)
I could have drilled these little holes on the drill press, but I have toolpost holder for a drilling machine on my lathe so used that.
The threaded end screws back and forth to extend the refill. I put a very small spring on the tip of the slimline refill to retract it.
A fun little pen and a perfect excuse to buy another tool:biggrin:
