SCustom
So far for all of my turning, I've been using relatively inexpensive tools.
I use an 8 piece kit I got at Harbor Freight. http://www.harborfreight.com/8-piece-high-speed-steel-wood-lathe-chisel-set-47066.html
Description of Windsor Design 47066
I also bought on the same day (because with a coupon I had it was basically free) this set: http://www.harborfreight.com/8-piece-wood-lathe-turning-tool-kit-3793.html
Description of Pittsburgh 3793
Made of heavy duty triple tempered tool steel, the 4-1/2" long precision ground tips let you to turn out work like a master craftsman.
I didn't realize how little work I would be able to do without constantly sharpening it every couple of minutes. It also just generally was not a pleasant set for me to use, so I'm thinking of selling it at the local flea market or a garage sale, or something.
The last set of tools I bought was this:
http://www.grizzly.com/products/HSS-Lathe-Chisels-5-pc-Set/H7941
Description
These beading scrapers make spindle turning and bowl beading easy and precise. Each high speed steel chisel measures roughly 13-1/2" long with beefy 3/16 - 1/4" thick blades and 83/4" ash handles. The tool tip design allows single beads or closely stacked beads for creative flexibility. The set includes 1/8", 1/4", 5/16" and 3/8" diameter bead scrapers and 3/8" diameter skewed double bevel beading tool. The chisel set is protected in a fitted wooden box.
Basically, I wanted my beads on things like candlesticks to be perfect and consistent. I still have a lot of practice to do to before I think I'm ready for an expensive high quality set for my regular chisels, BUT when it comes to pen turning, I've done enough of them down that I feel I've got enough practice to warrant an upgrade to a nice "Pen Set".
I've seen pen sets advertised that were made by Robert Sorby, Pinnacle, etc. I have no idea if these high priced tools are worth the money, or if you're just paying for the name?
For example:
From http://www.grizzly.com/products/Micro-Pen-Turning-Set/H9080
Description
These [Robert Sorby] micro turning tools were specifically designed for the pen turner. Each has a handle length of 6-1/4" with an overall length of 10". Roughing Gouge comes with a 5/16" blade, the Parting Tool with a 1/16" and the Spindlemaster with a 1/2". Buy all 3 and save!
From Woodcraft: http://www.woodcraft.com/Product/2020989/25248/Pinnacle-Cryogenic-3-pc--Pen-Set.aspx
Product Information:
Set contains a 1/4" Bowl Gouge, a 1/2" Oval Skew Chisel and a 1/8" Parting Tool.
Whether you are a professional production turner or a hobbyist with limited shop time, these cryogenically treated tools stay sharp two to three times longer than standard M-2 high-speed steel tools so you are turning more and sharpening less! Manufactured in Sheffield exclusively for Woodcraft, these cryogenically treated turning tools offer many of the characteristics of powdered metal tools without the cost of powdered metal tools. The cryogenic treatment process uses sub-zero temperatures, down to -300 degrees F, to modify the micro-structure of the steel into a more uniform grain structure that allows you to hone to a fine edge without chipping. Also, your cutting edge is more durable and more resistant to wear. Each tool is mounted in a European ash handle. The pen turner's set is the perfect set for turning small projects like pen and bottle stoppers. Appropriately sized (approximately 9" long) so you won't get worn out doing a lot of small turning like you might if using standard tools. The cryogenic blade durability will come in handy turning almost anything you can drive a pen blank into from the toughest plastics to the hardest woods. Three-piece set contains a 1/4" bowl gouge, a 1/2" oval skew chisel and a 1/8" parting tool.
<li style="margin-left: 20px;">Sub-zero cryogenically treated blades<li style="margin-left: 20px;">Manufactured in Sheffield, England<li style="margin-left: 20px;">European ash handles<li style="margin-left: 20px;">Woodcraft exclusive design<li style="margin-left: 20px;">9" Length
So How are these different or perhaps better than say this set: http://www.woodcraft.com/Product/2003974/9193/3-Piece-Pen-Turning-Set.aspx
Specifically designed for pen turning, these scaled-down High Speed Steel (HSS) tools are the perfect size for all your small turning projects. Tools are approximately 11" long with 8" handles, complete with wooden case.
High speed steel (often abbreviated HSS, sometimes HS) is a material usually used in the manufacture of machine tool bits and other cutters. It is often used in power saw blades and drill bits. It is superior to the older high carbon steel tools used extensively through the 1940s in that it can withstand higher temperatures without losing its temper (hardness). This property allows HSS to cut faster than high carbon steel, hence the name high speed steel. At room temperature, in their generally recommended heat treatment, HSS grades generally display high hardness (above HRC60) and a high abrasion resistance (generally linked to tungsten content often used in HSS) compared to common carbon and tool steels.
<li style="margin-left: 20px;">Set includes: 3/8" gouge, 1/2" skew, 1/8" parting tool<li style="margin-left: 20px;">High Speed Steel<li style="margin-left: 20px;">Designed and scaled down for pen turning<li style="margin-left: 20px;">Complete with a wooden case<li style="margin-left: 20px;">The perfect size for all of your small turning projects
OR THIS
http://www.pennstateind.com/store/LCPM3.html
Sharp and long lasting, this M2 High Speed Steel set is designed specifally for pen turning,. These tools are all you need to quickly cut your pen blanks with ease and precision. All three are 11" long. Set includes:
Basically, I'm looking to upgrade when it comes to pen working. I want something nice, but I don't know what nice is.
Thanks for any advice you can offer,
- High speed steel stays sharp longer than carbon steel
- Smooth Ashwood handles with lacquer finish
- Brass ferrules prevent handles from splitting under pressure
- Wood case
- 16-15/16'' long
- Includes 1/4", 1/2" and 3/4" gouge
- 1/2" and 1" skew
- 1/2" spear point
- 1/2" parting tool
- and 1/2" round
- 10" hardwood handles minimize operator fatigue
Description
For example:
Description
OR THIS
- Spindle Gouge for rough cutting: 3/8" wide and 3 1/2" long blade.
- Parting Tool for tenons: 1/16" thick and 3 1/2" long blade
- Skew Chisel for smooth cuts and finish turning: 1/2" Wide and 3 1/2" long blade
