spitfire
I did a casting for small project that wasn't a pen and ran into an issue. As you can see in the picture I poured the bottom red layer then waited until it became tacky and gelled then placed the picture on top of it.
The picture I printed onto photo paper on an inkjet printer then put a layer of modge podge on the front and back of the picture.
I then poured the clear resin on top while the bottom layer was still tacky to make sure the 2 layers would adhere. Everything was fine until resin was at the peak of curing(a few minutes after I poured it) it created an air bubble as you can see in the pictures. I don't know why this happened and wanted to see what I should do to not allow it to happen.
Also, the clear resin I had sitting in a cup of warm water to thin the resin a bit to eliminate air bubbles. Could it be that I used too much catalyst making it get to hot?
I put a small screw driver into the pocket and twisted a little and this is what happened.
