Tanner
Has anyone tried using this stuff to make a mood ring pen? My daughter asked me if I could make her a mood ring pen. If they can cast it into rings we must be able to make Mood Pens.
Sorta..... I'm still working on a "mood" pen. So far the best results have come from using the liquid plasma from devices like broken weather stations, plasma alarm clocks.
I'm still working with limited successes. I'll keep you posted as my experiment progresses.
I think it would look good cut like butch does with the MOP sheets
Gina with www.glimmerznmore.com use to carry them they changed to opiac with the warmth of you hand. Also had glow in the dark blanks![]()
I actually got some of the sheets a while back to try this but they are stiff plastic and don't want to stick to brass tubes very well. I have not totally given up but it wasn't as easy as wrap tube, cast, turn.
I was thinking, cut them in long thin narrow strips and glue them edge to edge length wise around the tube like an octagon or something.
Got my girl a mood ring once, turned blue when she was happy, when she was mad it left a big red knot on my forehead..........
I have 50g of thermochromic black/clear powder on its way. I'll let ya'll know how I do with it...
The powder came on Thursday. I cast a few blanks and the effect survived the casting temps. We (the vendor and I) weren't sure it would. I even did a post-cure.
The resin is more brittle with this powder in it.
I glued some slim tubes and will make a pen tonight.
The powder clumped in the first batch. Not noticeable in a 3/4" thick cast, but when turned down into a pen the clarity of the material is compromised by speckles of clumped powder.
The vendor recommended re-grinding it (!) I'll try mixing it longer. Or perhaps mixing it into a small amount of resin, then mixing that seed resin into a larger batch.
Yes, it does.
Well, it goes clear, showing whatever is underneath. Reverse painting the holes in the blank is recommended.
