Hi
this is my first time on this site and indeed any site! I am a callligrapher and would like to make my own nib holders/handles. can any of you point me in the right direction for starting up with smallest amount of equipment - I can get diferent woods.
any help gratefully appreciated - thanks
well, now, that question just begs for more questions in return. In theory, you can turn a nib holder with a drill and a screwdriver. Actually, you can do that in practice too, I've done it. But, realistically you probably want a lathe of some sort and at least a couple of dedicated turning chisels to do the basic shaping.
Now for the questions. Do you planning to turn handles for your existing nibs? Or order some new ones? If new, most will come with instructions on how to mount the nibs. But for existing ones you may have to figure it out on your own. Most probably will need a certain size hole drilled in the handle to slip into, or a specific size tennon turned on the end to slip over. The tennon is easy, but the hole requires some way to drill, and the right size bit to drill with before you start turning.
Second question, do you plan to create and polish attractive holders, or are you just interested in cranking out a bunch of working handles for a bunch of different nibs. If the former you will need a way to smooth out your turnings, some type of finish to apply to them, and some way to buff the finish to a shine.
And as for the wood that you can acquire, is is already sized relatively close to what you want your finished holders to be? If not, you will need some way to get it close to the right size before you start turning. Many start out with a small tabletop bandsaw, some probably keep using it, but most end up upgrading to something larger eventually.
So, the answers to these (and probably a couple more questions I forgot) will help us help you get a better idea of what you will need.
Most of all, if you get started turning, you will need lots and lots of money. This hobby is comparable in cost to a modest cocaine habit, from what I've seen.
James
