acrylic and no skew
bking0217
Apopka, FL
Is it possible to turn an acrylic without using a skew and still get a decent result? I haven't bought a skew yet but I have some nice acrylic blanks I'd like to turn.
I have seen my wife get a smoother finish with a fingernail gouge than I get with a skew. She was a wickedly light touch and tons of patience. I guess that is what she is still with me. :eek:
I've used a 1/2 round nose scrapper from start to finish many,many times. That being said on most I use the round nose scrapper and finish with a skew.
Just about any tool as long as it is sharp can turn a straight piece of material. I can use a parting tool and finish a blank. It is whatever you get used to. But remember sharp counts.
WoodPenPro. I use that from start to finish with acrylics. Then right to MM. Use a light touch and it is an amazing, diverse tool. Good Luck..
If I didn't have the Pro, I'd still be using my 3/4 Spindle Gouge. Works fine too.
I like a Carbide Pen Pro with a 2 in radius insert for every thing but Inlace Acrylester. for it I recommend a 36 grit on a 4 inch angle grinder then throwaway the disk and the blank..
:biggrin::biggrin::biggrin::biggrin: Now Ken, why not try and save the tube!
Charles
Have always used a 3/4 spindle gouge on everything I make pens out of. Used on an / or \ angle but not qiute as steep. For the heck of it, I,ve turned a pen with every turning tool I own.. Spindle gouge is my favorite.
well it sure isn't for your spelling.:biggrin:
just thought i'd throw that in there.:wink:
Depends on the acrylic, if it is inlace I use my 1" skew most of the way then finish with my 1/2" oval skew. If it is something more stable I will use the gouge then finish with 1/2" skew.
Day in day out the easiest tool to use for me is the gouge. By varying how I use it I can take off a good bit of material at the start and get a very smooth finish with a light touch. I mostly finish up with an oval skew.
Reading through all the replies there is a recurring theme -- SHARP TOOLS and a LIGHT TOUCH. To use a old analogy, its not the arrow, its the indian:wink:. Like all the others, I've used most of my tools at one time or another without a problem.
Carl
Ditto on the Pen Pro for everything except inlace. I use my cell phone on inlace... To try to find somebody willing to trade me something I CAN TURN!
Me and my skew LOVE inlace acrylester , that stuff shines like glass . Send me all your blanks and I will make sure they get good homes on my creations :biggrin:
I use my Hunter tool to to turn all acrylics to size then finish with my skew , it keeps me from having to do very much sanding .
Brian; One thing not mentioned is to knock the corners off square blanks with a drum sander or something similar.
I use a carbide tipped tool for all acrylics. This is especially needed for some of the very hard Trustone and M3 blanks.
