Looking for a yellow wood
Yellowheart? (also called Pau Amarello) I had a small block of it at one point and its fairly yellow. I don't know if I still have some or not.. But its a pretty plain grained wood from what I saw and its yellow.
I have a bunch of yellowheart that had been cut to about 1/2" inch maybe slightly thicker by about 5 1/2" long. Use them a-lot for slimlines.
But I'm with everyone else, recommend Yellowheart
Ceylon Satinwood!!! (Bought it years ago--very expensive)
I believe it could also be called Yellowheart---but then it's cheaper.
Osage Orange
Hedge wood salvaged from my inlaws firewood pile. aka Osage Orange
Yellowheart
Doesn't Osage Orange turn dark with time?
Yes, and its a beautiful wood. However, I think yellowheart would be a better choice if you want it to stay somewhat yellow.
The osage orange I've seen is usually not yellow to start with. Yellowheart is easy to work, plain grained and it is yellow. If you don't find it elsewhere email/IM me.
I'm with Lupe on this one.....agarita is the way to go. It has a yellow that you just won't find in the other woods. As he mentioned, finding a solid piece that is large enough is sometimes a challenge, but it is well worth the trouble if you can locate a piece. You might check and see what Mesquite Man (TurnTex) has that might work for you.
yellowhart is temp sensitive
My wife keeps her YH in a small refrigerator in her shop. She takes it from there straight to the lathe. Be careful when drilling it.
