bking0217
Can you sharpen a standard grind spindle gouge with the basic Wolverine sharpening jig? I need a sharpening setup but I need to spend as little money as possible this time of year.
Yes, you can. It will take practice, but you can do it.Can you sharpen a standard grind spindle gouge with the basic Wolverine sharpening jig? I need a sharpening setup but I need to spend as little money as possible this time of year.
That's what I was hoping. I was looking at the bevel on my spindle gouge and I still don't see how it's going to work but I don't have the jig in front of me so I'll get that and see what happens. In a perfect world I'd get a Tormek, but...
To be quiet honest with you, if you could swing the varigrind attachment, your life would be MUCH easier.
And, I had a Tormek, a WorkSharp 3000, Grizzly 10" and the Wolverine. I now have the Wolverine system and the Grizzly. I think the Wolverine is the best system out there (FOR ME) and it puts a scary sharp grind on anything (except planes) that I have. It is a lot faster than the Tormek.
BUT, if you are truly looking at a Tormek, also give the Grizzly system a look-over. Almost the same thing, just a lot less expensive, and 90% of the Tormek accessories work with the Grizzly system.
Have you used both the Varigrind and the Varigrind 2? If so, how do they compare?
What are the Raptor setup jigs?
Just a note, PSI makes a copy that's much less $$, and even cheaper on Amazon, I believe. The Amazon bundle comes with the Varigrind and skew attachments.
The platform is great for sharpening skews and scrappers, and free hand sharpening.
