Finish for horn?
drgoretex
Winnipeg
Just wondering if anyone has any experience with horn. Just got some buffalo horn, looking forward to turning, but not sure what finish would best suit it. Could do my usual CA, but wondering if anyone has worked with this material...
Ken
When I made my Indian Water Buffalo horn pens I applied layers of thin CA until it stopped soaking it in then moved on to medium CA.
From my experience with buffalo horn you need to use a crack resistant finish.:biggrin::biggrin: I stopped using it after the first 4 or 5 cracked. There are too may other wonderful materials to use. I wish you well. Maybe buffalo horn is better now than it was a few years ago. Oh yea, any good finish should work. I would us CA if I were making another buffalo horn pen.
Do a good turn daily!
Don
Ken
Thanks for the advice!
Crickett - nice pen! And say hi to the lower mainland for me. My old home was Richmond (Steveston) for many years.
Ken
I have worked with Asian Water Buffalo horn and also ox horn. Both materials are similar with the ox horn having more white and some yellow in it. Both materials will take a beautiful finish by just buffing. Horn has been used for over a hundred years in the cutlery industry for handles on knives without any additional finish except buffing.
Horn is often attacked by beatles and other insects. Horn makes a very nice pen and perhaps should be wiped with a little lanolin once in a while.
I've used many versions of horn over the years, as knife scales and pen blanks. It's all prone to crack, and will often turn white if crushed. I never put a surface finish like CA on horn. Buff it to a high shine and coat liberally with wax to try to postpone the cracks as long as possible. Storing in a consistent temperature and humidity environment away from sunlight helps too.
And when it does crack anyway, in spite of everything you do, use some black ink to tint the crack, and some med CA to fill it, and then sand back down to the bare horn to repolish and buff.
Beautiful stuff, but a pain to work with.
