Another Parker gel question
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Are parker gel refills always interchangeable with parker ballpoint refills? I've used both but never really tryed to swap them.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Parker ballpoint refills have the distinctive "sawtooth" top--any refill you want to use should have the same "sawtooth".
Sylvanite
I've found some of the gel refills are slightly larger in diameter at the tip than the ballpoint refills. That leads to an occasional tip that doesn't quite fit through the nib. In such cases, I ream out the nib with a #38 drill bit and then everything is fine.
Regards,
Eric
its_virgil
Wichita Falls, TX, USA.
But I think the "sawtooth" is only important if the pen is a click pen. The sawtooth is not necessary for the twist ballpoints. I have made one or two :biggrin: twist ballpoints where one of the barrels (or both:biggrin::biggrin:) were too short and the ink fill propelled too far out of the pen's end. Not wanting to disassemble and redo the pen, I just removed part of the plastic sawtooth plug and the pen worked fine....as one of my pens to use, not to sell.
I have used about every Parker style refill and they have all worked fine. Eric's post about some having a larger diameter tip has happened to me and his solution was the same that I used.
Do a good turn daily!
Don
ed4copies
Racine, WI, USA.
I agree, Don, that the Sawtooth serves no purpose in our pens, but it does identify refills "made to be used in Parker pens"
