sgimbel
What speed do you run your lathe and what grit do most of you start at?
I slow the lathe down for sanding to about 500 RPM. Running too fast can generate heat that will discolour the wood or melt the MM pads.What speed do you run your lathe and what grit do most of you start at?
If you get any blooming or hazy spots using water Todd, give the accelerator a try instead. Never know.
