Grizzly G0462 Lathe Hand wheel?
termitepenman
Guinsularan, Bohol, Philippines
I bought a variable speed mini lathe at HF. It had no spindle wheel. I went to TAP Plastics and bought a 2" X 3" round of Delrin for $3.00. I drilled a hole in one end of the round and compress fitted the spindle nut into the round. Then I drilled a hole through the round for the push rod and WaLa I have a hand wheel. I will be posting some pictures of the modification in the next couple of days.
_________________________________________________________
Dennis Patzer
Sacramento, CA
rjwolfe3
Mansfield, Ohio, USA.
There was member selling hand wheels for certain lathes but I don't know which one they fit. If I find their name I will post it here. I am in the same boat with my big Harbor Freight lathe.
spnemo
Tustin, MI
There isn't enough room on the end of the spindle to jam something on. I will have to thread it into the internal threads. This doesn't leave much room for a hole for the push rod. So, I think I will have to find out what size the threads are and make something out of metal to match.
spnemo
Tustin, MI
Thanks! I think the two lathes are very nearly the same. Hopefully we can both find a solution to the problem.
randyrls
Harrisburg, PA 17112
spnemo;1085081 Does anyone know what the internal thread size is on the back side of the spindle?[/QUOTE said:
Sean; I don't know what thread it is, but it is likely a metric thread. Measure the thread with a leaf type thread gauge and then check the ID of the hole with calipers.
Do you know how to attach a hand wheel to this lathe?
I would turn down a wood cylinder to just fit inside the hole, then drill a hole thru the cylinder and add a taper to the far end. Put 4 slits part way thru the cylinder. Turn down a handle and nut with a matching taper and tighten the cylinder to hold the handle in place.
Grizzly doesn't want the help me on this one, so any help is greatly appreciated.
That is unusual, their Tech Support has been more than willing to help me with odd questions..... :confused:
spnemo
Tustin, MI
Have you tried using your face plate as a hand wheel. That's what I did before I modified my HF mini.
__________________________________________________________________________
Dennis
Sacramento
Yes, but I keep turning the face plate the wrong way.:eek:
spnemo
Tustin, MI
I just heard from Grizzly that the thread on the back side of the spindle is 1/2"-12 TPI left hand thread (same as the HF model). This is a really odd size. I have a friend who works at a machine shop doing some checking for me but he thinks it may have to be a custom job.
maxwell_smart007
Lead Moderator
Staff member
middle of nowhere in the great, white North
Did a lot of digging, but I found it! I was going to order one for myself, but I cannot have it shipped up here (because it's labelled as Jet, and they can't ship Jet branded tools into Canada!!)
Crap!
But here's the info for those of you who CAN have it shipped to you down there. 13 bucks, plus shipping! :)
Jet (WMH) customer service center:
Phone: 800 274-6848
Tech service: 800 274-6846
Part # WMH-708344
spnemo
Tustin, MI
Crap!
Phone: 800 274-6848
Part # WMH-708344
Does it come with a 1/2"-12 tpi LH bolt to attach it to the lathe?
monophoto
Saratoga Springs, NY
I'm not familiar with the Grizzly, but my first lathe (a ShopFox) didn't come with a handwheel, and I was able to make something to fit.
My recollection is that I found a YouTube video in which someone discussed making a handwheel, and that provided inspiration/guidance/a starting point for making my own.
It turns out that there were two nuts on the outboard end of the spindle shaft - both were left-hand thread (so that they will tighten as the lathe turns). I don't recall the size, but that's irrelevant. There was a plastic cup that covered the end of the spindle shaft. My approach was to remove and discard the plastic cup, and then unscrew the outer of the two nuts. I then turned a handwheel from a scrap of oak, with a recess in the center to receive the nut. As I recall the process, I made the recess a bit smaller in diameter than the corner-corner dimension of the nut, and then used a bench chisel to cut some notches in the side of the recess to receive those corners. After sanding and and applying a WOP finish, I glued the nut into the recess with epoxy, and when the glue dried, screwed the handwheel onto the shaft.
