razor524
I made a pressure pot per the directions on the forum. It keeps leaking air from under the rim. I put jb weld around the inner seal to patch any small holes, tried clamping it down very tight with pliers, nothing works. Any ideas?
flip the gasket over put a coat of silicone grease on it and tighten it down, sometimes you haveto turn it a bit at a time to findthe sweet spot. Once you do, mark it with sharpie so you can line it up again.I made a pressure pot per the directions on the forum. It keeps leaking air from under the rim. I put jb weld around the inner seal to patch any small holes, tried clamping it down very tight with pliers, nothing works. Any ideas?
flip the gasket over put acoat ofsiliconegrease on it andtighten it down, sometimesyou haveto turn it abit at atimetofindthesweet spot. once you do, mark it with sharpie soyou can lineit upagain.I made a pressure pot per the directions on the forum. It keeps leaking air from under the rim. I put jb weld around the inner seal to patch any small holes, tried clamping it down very tight with pliers, nothing works. Any ideas?
Thanks for the advice everyone, I have a few things to try, even though after reading Bruce's post I'm now kind of scared of the thing!
