CMS Updated w/Shop Pics
Whaler
Sequim, WA, USA.
I have shopped long and hard for a CMS and finally settled on the Makita LS0714 7 1/2" slider.
I hooked it up to the shop vac and cut up some 2x2 as a trial. Out of the box everything was right on, the factory supplied blade is excellent and the dust collection is fantastic.
I give it 5 stars.
Dick,
Congratulations on the new saw. I picked up one a couple of years ago to replace an old wore-out 10" CMS. My experience is the same as yours---dead on accuracy right out of the box. It has held up very well, and the light-weight is a great bonus if you move it around. I'm sure you will really enjoy it.
Larry
Dick,
I too, have that saw and have had the same experience. It is a great tool. I originally put it on a middle of the road stand, I recently upgraded those and it is even more awesome.
I just replaced the blade after about 4 years with a Frued CMS blade, it is an improvement after the old duller blade.
Your shop looks great in the background, how about more photos?
Mike aka Moke
Dick,
Mike aka Moke
Mike, here is a tour of the shop. It is 1/2 of a two car garage and is a work in progress. All of the heavy stuff is on mobile bases so they can be moved as necessary. I used a Delta T2 fence on the TS rather than the DW fence and added an Incra miter gauge. I didn't have room for a router table so I made brackets and hung it from the TS rails. The CMS is in a temporary location until I come up with something better.
Dick,
That is a great shop! My shop is in the garage and I too, have most everything on wheels. I push it all into one stall and spread it out when I want to use it. The difference between my shop and yours is, YOURS IS REALLY CLEAN!!! WHITE TOO!
A couple things, I have a similar Delta DC..except mine is "pre" cannister...I modified it to take the clear dust collection bag, but is it worth that $200 for the cannister? Then, I have an old Craftsman Bandsaw, like 1948, I have worked on it some: tires, 1/4 cool blocks, Rockler table, and light....I have really never used a new or good saw, is that worth it? Is it noticable?
Thanks for taking the time to show us your shop--I like getting ideas!!
Mike aka Moke
Dick,
Mike aka Moke
Mike
I really like the canister but it is an expensive conversion. You might look around for a 1 micron upper bag to fit your DC it will probably work just as well and be a lot cheaper.
I doubt that a new saw is any better than a properly tuned old saw with a good blade.
