Thompson Tools?
Yes, I have one of his bowl gouges I like it, it stays sharper longer than my other ones do.
He seems to be a pretty good guy also, cause last year, after hearing he was not going to make it to SWAT, I emailed him to see if I could get an order together between the three clubs that I am in to save on shipping. He answered my email saying he would work with me anyway he could. I thought that was pretty cool.
I have several Thompson Tools, gouges and skews, and love them. They stay super sharp for longer that my Sorby's. I've run into him at two symposiums, and he seems like a nice guy.
I have one of his bowl gouges. I've only used it once or twice so far, had it over a year or so. So I can't really give you much input. I will be using it more in the future as I try to expand on my turning adventures. If you are only going to be turning pen, I don't see why you would want or need one. But if you are turning other things, well, I have heard nothing but good about them. One thing I am a little concerned about is I get the impression they are difficult to sharpen. Those with experience, is that true?
I'm going to be making end-grain boxes, so I want a spindle gouge. His web site says he sharpens them initially on a Wolverine.
They (well, "he", I understand it's a one man operation...) are right on my way home from work
That right there would bankrupt me :biggrin:
Talk to him about the Michael Housalak detail gouges that he makes. A detail gouge is similar to a spindle gouge. I first heard about it reading Richard Raffans book on box making. I assumed it was just Australian for spindle gouge, but that is not the case. I have a set of the Michael Housalak detail gouge made by Thompson and I really like them. I have not picked up my spindle gouge since I got them.
I also have one of his bowl v-gouges, got it used from a member here, and really like it.
I've got five of his tools... Three different bowl gouges, a skew, and a detail gouge. Most of the turning I do is outside of pens, and I really like Doug's tools and his customer service.
For high end tools, the price is right, and I like the idea of not paying for a handle when all I really want is the steel.
Jeff, Doug is kind of a friend of mine and gave me some direction when I started making my Woodchucks, I have a couple of his Bowl gouges one is his Jimmy Clewes signature model and I'm not ashamed to say I use it quite a bit. The Steel he uses is one of the very best tool steels available for wood turning tools, it will sty sharp longer than most other lathe tools other than Carbide. Doug puts a lot of work into his tools, and they are worth every penny.If you stop by tell him Ken Ferrell said Hi, and send to me a commission check LOL
I have one of his bowl gouges. One thing I am a little concerned about is I get the impression they are difficult to sharpen. Those with experience, is that true?
Paul they are just as easy to sharpen as any other Bowl or Spindle gouge, you should use a good jig like a Wolverine or something comparable, but they are no harder to sharpen, and they hold an edge longer than conventional High speed Steel.
I have found that they sharpen just as easily as my Sorby HSS tools. I use a Wolverine to sharpen the gouges, and a DMT hone to refine the edge.
Since the Thompson holds its edge better, I always use it for finishing cuts.
I have a larger Sorby bowl gouge that I will continue to use for roughing until I wear it out and will then get a matching size Thompson. I go down a size to my Thompson once I rough out the shape to get the final profile and surface cuts. The Thompson has been a real blessing now that I am turning thinner walled vessels (1/8" or thinner)
Keith - you use the Housalak gouge for end grain boxes? Which size do you use?
I have three sizes, 3/8", 1/2" and 5/8". I use all three as follows:
Shaping the outside and detail work: 3/8" and 1/2"
Hollowing: 1/2" and 5/8"
If I had to pick two I would get the 3/8" and 1/2".
If I had to pick one I would get the 1/2".
Michael does sell more of the 1/2 diameter than the others. I just moved the shop to Lewis Rd. in Berea.
I will chime in that I have three of his bowl gouges, and a detail
One is johannes tool
Two are Jimmy Clewes series
but there is a trend on here that kind of confuses me.
Most of the people here are stating that the tool stays sharper than anything else they own. And this is true
However, do the people respond turn with a tool edge they have been roughing with?
I always try to sharpen my tool for the last cut or two that I will be doing. Typically this makes for less sanding.
Sorry to upset the apple cart.
BTW, I do notice a big difference between the feel of how my Johannes tool sharpens (which is from 2007), than how the two clewes tools sharpen, which were from hartford aaw symposium 2010.
Jerry
