RyanNJ
Has anyone who has turned a carbon fiber blank experienced lots of chipping?
Like John said above and with all pr, if your too aggressive it can shatter and chip away very quickly, especially near the edges. Been there, done that many time.![]()
What rpm is better
2465 or 3950?
What rpm is better
2465 or 3950?
Thanks for the info JeffI never have good luck on PR using either the Woodchuck or the Rotondo carbide tools. I think both tools are too aggressive for this material. A sharp gouge and a sharp skew will both focus the material removal to a smaller line on the blank. PR is touchy as it is more brittle than your average blank. Bottom line is the chipping is because of you, not a bad blank. You will get lots of different answers on how to turn PR.
Ryan, I turn the cf blanks at about 3000 rpm and use the woodchuck. LIGHT cuts, if you get a bit aggressive, the carbide bit will bite and dig hard and fast into the pr. A replacement blank is on the way and I also sent a couple "reject" blanks that have small defects in them to practice with.
