rd_ab_penman
I have had great results getting bubble free castings without the use of a PP or ultrasonic cleaner or any other vibrating devices using Resin Saver mold.
1. Slowly pour required amount of resin into a plastic cup letting the resin run down the side wall of the cup to avoid creating any air bubbles.
2. Place the plastic cup of resin into a shallow container filled with hot water at a temperature of 42C ( 115 F )
3. Add the required amount of catalyst to the warm resin and stir gently for two minuets to avoid creating any air bubbles
4. Once the resin has warmed enough to reduce the viscosity similar to water it is ready to pour.
5. Slowly pour the warmed resin into the mold and using a tooth pick remove any air bubbles that may form in the resin. Resin usually starts to gel in 10-15 minuets.
6. Place the mold into my warming chamber for 6-8 hours to cure.
Les
Les
