CA with Acrylic pens???
toyotaman
NW Georgia (USA)
I was wondering if you can use CA glue on an Acrylic pen?,and if you can does it really make that big of a difference other then MM and polishing?
Toyotaman
I like doing it. I use 6-10 coats of thin CA. I like the shine I am able to produce and it's a more durable finish. That's just my technique.
This is one of the times you need to differentiate "acrylic" from Polyresin and Alumilite.
"Acrylic" is manufactured under far greater pressure than the "home hobbyist" can produce. Hence, it will not have "bubbles". No CA is required, and I have never seen an advantage to using it.
With "home pressure pots" there is a possibility of bubbles in polyresin and alumilite. CA is a great way to hide and, actually heal these voids.
There is certainly room for differing opinions in this matter!!!
