Baron Rollerball in Antler and Ebony
See more from Pioneerpens
Pioneerpens
Huntington, WV
I made this Baron with Deer Antler and Gabon Ebony...I liked the contrast of the two colors.. Comments always welcome!
Thanks for looking!:smile:
Awesome pen, Jennifer...
Do you have any trouble with the Gabon Ebony cracking?
The only way I can keep it from cracking, is to cut the blank, drill it out, using water as a coolant, and then allow the blank to cure out, in my refer/kiln. So far, so good...
How about you?
Thanks Jim..Allen~ this is the first time I have turned the ebony. It had a small crack to start with so I used ca on it to start. I drilled very slowly and stopped a few times just to let the blank cool down. I added ca several times~ just a drop~ on the crack during turning and sanding and it sealed it nicely with no others occuring...Perhaps beginners luck? lol
Jennifer, don't turn your back on it, it WILL split.
