To buy a Metal Lathe Or not to!!!
Here's a pic of my two newer lathes next to each other. Note how small the stand is of the 9 x 20 is and how small the knobs are. The lathe is also raised up on 6" aluminum blocks. There is some chatter doing a facing cut due to the machine not being stiff enough. The new 12 x 36 is next to it. It has gear levers to change speeds, and is a lot stiffer and smoother machine. The knobs are larger and much smoother turning. It's almost too tall, about 3" taller than my older 14 x 42 lathe, which I'm used to.
Yep..that's a great machine. Mine is almost the exact same machine, different manufacturer..simply means a few of the buttons on the gear house are in different spots but otherwise the machines look identical. I think the only real difference is the user...So I won't show my lathe your lathe or it might get jealous! :smile:
Now I really have lathe envy......boo hoo!
My only concern with all of this is that you have not said why you are thinking of buying a metal lathe nor your level of experience ,both factors needed to determine suitability of a given machine . The differences in turning wood and making pens on a wood lathe are vastly different to turning steel on a metal lathe :) . As a retired fitter and turner going from metal to wood was a fairly easy curve ,especially as I only make pens lol. Going from wood or plastics is a whole new learning curve . Tool cutting angles speeds and feeds are all things that need to be learnt as well as cooling and lubrication of the work pieces ,you certainly can widen your horizons a lot with a metal lathe for sure ,My first acrylics and truestone pens were done on a metal lathe till I got better control of the hand tools hehe. This is something I knocked up last week to aid in my pen turning ,a mandrel saver utilising a clutch throwout bearing from a "Mini "
Cheers ~ John I say go for it hehe ( the lathe that is )
and how do I get the tractor into my basement?????????:eek:
Did you not see the 60 inch bucket on the front ??? You dig man! Dig your way inside...or you can use the chains hooks on the front to pull the door open a bit larger, or just ram it in! :biggrin:
Tell the wife about all the flower gardens you can make for her with the John Deere.:wink: Owning the tractor is just as fun as the lathe.
All to make a 5" pen .....
