Churchill Pen - Black Tru-STone w/Gold Matix
See more from JD Combs Sr
JD Combs Sr
Owingsville, KY
Turned this a couple weeks back. Wanted to see what the group thought of it. It was turned for a bank loan officer. I generally post on SMC because pens are just one of my hobbies but thought this one might deserve wider exposure.:smile:
I like the color combination. Very classic. I see it has the improved metal coupler between the section and the body. I'm curious, is the fountain pen section 3 piece, with the nib, feed and a one piece molded plastic body, or is there a separate outer housing and inner nib holder threaded together?
Oh, yes, and where did you get the kit, if you remember?
I'm doing an informal survey :-)
The nib and nib holder with feed is one piece or at least I see no way to disassemble it short of ruining it. There is a gold accent ring that goes around the threaded end before it screws into the metal coupler. The kit came with both the plastic and metal coupler and I saw no reason to use the plastic one, just threw it into the back of a supply drawer on the maybe.
If I remember correctly the kit came from Berea Hardwoods.
