RyanNJ
Is it worth it to buy a photo tent to capture good pictures?
Can one be made or where is a good place to get one
do you remember what size or the seller you got it from?I got mine on ebay for $25 plus shipping (like $10 or something) Made a world of difference on the lighting. I would say it is worth it.
I made one from 1/4 dowels and white liner frabric. just made small cubes for the corners and drilled them with a 1/4 drill and glued it together. 18inches cubed, you can drape the fabric over it and use small clamps or those fold over clips from the office supply stores.
You don't necessarily need to "stretch" the fabric. it should just be reasonably non-wrinkled, and ideally it would be attached to the inside of any frame you make (or paint the frame white) as any dark lines around the tent would show in the reflections in our little shiny subjects...
I used a good sized (24"x12"x12") Cardboard box. Cut "windows" in all sides and hot glued white fabric, Walmart, all around. I use a small box as a platform and hang a sheet of fabric inside and over the box. Picked up a 100w DayLight from Lowe's and a shop type reflector/worklight and Shazam! $14 was my total cost. Not real pretty on the outside, but good results so far![]()
how many lights would i need and where would i place them
