Microwave Turntable
Jgrden
hOUSTON, Texas
Why is it that when I put a cup onto the turntable and microwave for one minute, does the table stop with my cup on the extreme back side and not the front where I first put it????:confused::frown:
:biggrin::biggrin::biggrin:
Because it likes you?:) Start it in the back and trick it back.
:biggrin::biggrin::biggrin: hEH, HEH. Wait a minute!.. Okay so I trick it while it tricked me to unnecessarily reach into the BACK of the microwave. Can't fool and old fooler - although you nearly did. :at-wits-end:
If you take the door off and jam the door safety switch, you can stick your head in while the microwave is running and see what is going wrong. No need to thank me, it's my civic duty to help where I can. :biggrin::biggrin:
:doctor:With friends like you............ frocket gun.gif
Place you cup in the middle of the turntable...... Or as the sign says at our local bowling alley "Shut-Up and Adjust".
John, don't listen to these jokers!!!:mad: It means that it's not hot enough yet, just keep nuking it till it ends up in the front again.
You might need an asbestos mouth though. :wink:
I don't know how some of you guys can sleep at night....giving a guy dangerous advice like that!!!!!:tongue:
I rigged my microwave to work in Nano-Seconds. I can nuke that baby for 2 Nano-Seconds and it turns into Expresso!! 3 Nano-Seconds and you have Cappucino!! Pick your poison.
Duhhhhhh .... CA is my answer. Does several things, (1) Keeps your cup in the center as long as you glue it correctly in the first place, (2) You NEVER have to hunt for your cup again, (3) You NEVER have to wash it either. Besides, doesn't terrific heat kill all germs??
Now as to how you get your noggin in there to drink it, I ain't quite got a good answer for that one yet. Give me a day or so to ponder it over a bit and I will! :eek:
Have your wife do it! Then you dont care where it stops, and tell her to be quick about it.
A straw is obviously the answer. One of those long swirly ones.
Are you having a problem with short arm syndrome?:eek: Just how deep is the microwave? I guess someone is having a caffeine withdrawl issue this morning?:coffee::coffee::coffee:
Ok if you set the timer @ 30sec.at first time, then cut the time in half !!!!! and the cup will be up front>>>>>>>>>>>>>>>>>>>>>>>>>>
Simply put, the period of rotation for the turntable is either greater or less than the period of exposure as determined by the timer.:biggrin: (don't ya just love engineers!!)
OMG, never thought of this. By doing this you will have a permanent built in saucer just in case you spill some of the coffee. Should I use thick, med or thin CA?
