Total Wood Concept
KDM
Redditch, England
This was a concept pen. I might call it pen number 6. Can't think of anything more imaginative right now. The deal was that it should have nothing but wood showing.
I needed a skinny brass finial which you can just about see. It's a twisting ball pen based on a slimline transmission and you'll notice the twisty bit is at the top rather than in the middle. I was going to link to the post which gave me that idea but I can't find it again.
workinforwood
Eaton Rapids, Michigan, USA.
It's been described as something much worse. Something unmentionable in polite company.
:devil:Was it something like.... is there a ribbed version available and are batteries included? :party::biggrin:
And more seriously..as Butch says, at least you have the concept down. Once you understand how it all works, you work on your design. It certainly needs to be toned down on it's current look. Some segmenting would dress it up quite a bit from just being a plain "drumstick". Just a simple contrasting piece of wood for a centerband would add a great deal to the pen.
Rotherham, United Kingdom, Britain
Great idea!
I did something similar. If I removed the metal clip, the pen I've attached for viewing would be completely turned from wood. I set upon the idea when I got fed up of turning the same old kits time and time again.
Your pen, for a first attempt, shows great promise. Styling is such a personal issue on any pen made that I wouldn't let it bother you too much at present. Further attempts will, I am sure, define themselves until you settle upon a shape pleasing to the majority who see it. And a little decoration to the blanks will also go a ways to adding a pleasing element to the design.
I think the most important thing for you to do at the moment is keep turning and being creative. You are certainly well on the way, and I bet it won't take you too long before you hit upon a series of all wood pens that you will be posting on here for us eager pen makers to see.
Well done and keep it up. I can't wait to view more of your work. Many thanks for sharing.
Rfturner
Santa Maria, CA
It is a start, maybe take it a step further and make it in a drumstick pen...for a drummer. Segmenting will help it though not look so strange
KDM
Redditch, England
Sadly, yes.
I do agree. Irritatingly, I was aiming for a plain 100% wood pen. No embellishments. It did turn out a little more boring than I had hoped. I like your idea of using a band. Perhaps a bit of beech or oak.
KDM
Redditch, England
Ooooohhh.... I like the idea if using little plugs through the pen. (I presume that's what they are.)
... a series of all wood pens that you will be posting on here for us eager pen makers to see.
I've said it elsewhere, but I'd really like to see someone code up a little tag you can add to a post which identifies it as a "pen". I'd like to "find all pens by Turnedwritepens" for example. In fact all 8 (to date) of my attempts are posted here. Even though theer are only a few, they're still not necessarily easy to find.
KDM
Redditch, England
How about a "How I Did It" with PIX???
:wink::wink::wink:
Hmmm... Could do, but the only non-standard part is the finnial which is just a piece of brass rod 7mm dia with a 2mm hole. I'm not well placed to start a tutorial on how to turn wood, 'cos I'm just an amateur!!!
workinforwood
You can do a search for posts by a person, you can do search for threads by a person, then you can narrow that down to category, so you can find all threads started by Mr Smith, in the Show of your pens area. if he started a thread, he must be showing a pen. Not every pen shown in a thread will be in his personal gallery and vise versa, but either way, that is still another option, you can go to the photo gallery and see what MR Smith has uploaded...chances are if he uploaded them, they were pens he really liked.
