Centering Bit
JBCustomPens
Everett, Washington
Could someone tell me what number centering bit I should buy for pre-drillng.
There is no number to use. All center drills drill a 60 degree hole and pre-drill just fine. I use a number 4 I got from JohnnyCNC. Again, he is a great guy to work with and I will always recommend him and his products.
holmqer
Local Chapter Leader
CT, USA.
Actually some center drills are 82 degrees and some are 90, for our use generally 60 degrees is good.
I tend to use a number 3 or 4. I use 3 on the smaller kits like 7mm and 4 on larger.
rherrell
Pilot Mountain, NC
They're so cheap I recommend you get the assortment pack, it's either 4 or 5 drills for just a few bucks. The tip of the drill bit should be equal to or smaller than the center bit.
holmqer
CT, USA.
I quite agree, I have some by my metal lathe, milling machine, drill press and wood lathe
